Home › Forum › Ask A Member › Elto battery coils 1930’s
  • #4125
    weedlessdrive
      Does anyone have info on Elto battery coils from 1930’s? Are they more reliable than ones under flywheels? Did Evinrude produce them or were they Elto only?
      #35463
      Casey Lynn
        Contact George Emmanuel. He has done quite a lot of work in this area.
        #35464
        RICHARD A. WHITE
          Are you referring to the ones used on Battery ignition Elto’s? Round tube used on opposed twins, fires both cylinders at the same time?
          classicomctools@gmail.com
          #35481
          weedlessdrive
            Richard, Yes those are the ones I’m referring to. I am wondering how they work, if they run off the same points and condenser? If anyone has diagrams or info on them.
            #35485
            RICHARD A. WHITE
              More often than not the condensers go bad, and you can’t just replace them, due top the potting used, it is NASTY stuff. You can, by following our own "Tubs" videos on Youtube, find out how to replace the entire ignition, i.e. coil, and condenser using a Zephyr coil and a common condenser, the points are not in the tube.. The coil generally gets destroyed when removing the condenser.
              OR, you can just contact, Doug Penn, as he has them already rebuilt, just connect and go…
              #35518
              weedlessdrive
                Thanks Richard! I Pm’d George and checked out Tubs video on changing out the coils. Hopefully George will have info on how the battery and system connects and works.
                Thanks
                #35527
                RICHARD A. WHITE
                  If memory serves, battery connections are somewhat irrelevant, but I recall reading somewhere that you should switch POS and NEG occasionally.
                  #35562
                  George Emmanuel
                    Weedless,
                    I’ve been away from the private messages a bit but I did respond today..It is best to communicate with me via e-mail: gemmanuel@bellsouth.net so can send some pictures.
                    I have heard the same thing Richard said because reversing the polarity maintains the points.
                    George
