Home › Forum › Ask A Member › Elto Ace coil
  • #4149
    David Stanton
      Anyone know of an available magneto coil I can modify to fit a 1.8 HP, 1940 Elto Ace?
      tom-c
        I put a modern OMC coil in mine. Had to modify the laminates but I got it to fit and works great.
        #35616
          I hope this helps . . . 😀
          1939 Ace – ’40 Ace had a rubber clutch in the propeller hub …
          #64699
          dwood148
            Tom,
            I too need a coil for my 1940/1941 Elto ACE 4351.
            Can you let me know what OMC coil it was that you have used?
            #64761
              Its pretty common for this magneto
              to loose spark because of corrosion
              in the point assembly. Disassemble
              the points and clean everything and
              recheck for spark. These coils are
              rarely bad. I bet I have had 20 or
              more motors with this magneto
              that wouldn’t spark when I got them
              but it was never the coil. Its always
              good to know if there is an option if
              you do find a bad coil so how about
              a picture Tom?
