Home › Forum › Ask A Member › Elto Ace 1.8 low compression
  • #5433
    djeady
      I’m still trying to get my old Eaton Viking/Elto Ace running. The spark and fuel are good, I just don’t seem to be getting any compression.
      I’ve put in new rings (couldn’t see any difference between old and new) honed the cylinder, and used gasket sealer on both sides of the gasket. Cylinder looks fine, piston looks fine. Used a brand-new compression tester as my old one was suspect. I get compression of less than 20 dry and about 25 wet. I think it should be about twice this. Any ideas where to look next?
      #45262
      RICHARD A. WHITE
        Upper and lower crank seals….or lack there of…
        meaning crank case seal..
        classicomctools@gmail.com
        #45264
        djeady
          How do the crank seals,which are below the piston and head assembly affect compression which is entirely inside the cylinder head?
          #45268
          wedgie
            The crankcase pressure is used to push the fuel/air in to the cylinder. Low compression in the crank means not enough fuel/air. http://imgur.com/gallery/eatFH
            #45273
            djeady
              I understand that – don’t understand how it could affect the compression measured in the cylinder?
              #45275
              wedgie
                quote djeady:
                Looks can be deceiving. If the cylinder is too worn, new rings wont be enough. You can get an idea of how worn the cylinder is by measuring the gap of the new rings when they are inserted (without the piston) in to the cylinder. I don’t know what the gap should be, but hopefully someone here will have that info.
                #45283
                  Piston to cylinder clearance should be minimum .002" to maximum .0035" – The 4256 Ace uses the same 1.75" piston rings as the Lightfour – end gap .006" to .016"
                  #45285
                    At .004" clearance you may have to use SAE 40 wt. oil to get it to seal properly. At .006" piston to cylinder clearence bore it out and use oversize pistons .
                    #45295
                      quote djeady:
                      They don’t. In a two-stroke motor, atmospheric air pressure enters the cylinder thru the exhaust port every revolution while doing a compression test with the motor mounted on a stand. Leaky seals will only affect the operation of the motor as they will cause a lean condition if leaking air in or poor running if leaking the fuel/air mix out.
                      #45302
                      GARY
                        Is your compression gauge of the long or short hose variety?The smaller the motor the bigger the difference it can make.
