Home › Forum › Ask A Member › Elgin Tillotson MD100A carb issue
  • #277250
    Hello All. I am trying to restore an Elgin 7.5 model 57158781. It has a Tillotson MD100A carb. I am having difficulty finding out how to connect the carb to the fuel tank.  I have a screw on petcock valve, but the carburetor connection looks to be a push on. I have a screw on petcock fuel valve however,
    this obviously it will not work.
    I have included photos for reference. Any help finding this part would be appreciated. I am also looking for the front fuel valve plunger.
    Thanks for your help. This should be the last step in the rebuild or at least I hope so.
    Kevin
    #277254
      According to Tillotson data, that is the correct carb for your motor.
      I recently worked on a Clinton outboard carb that had a push in fuel
      fitting that was missing, so I made one.
      Was the shut-off / petcock original in the front of the motor on that model,
      or back on the gas tank?
      Look on Ebay or advertise on the free ads on this site, for a parts carb.
        If memory serves correct, that would take a standard flare adapter.  Sorry, but you’ll have to do the homework yourself.  This might get you off in the right direction.  Or not.
        tube fittings | McMaster-Carr
        #277299
        Hi there
        The fuel valve was st the front I believe. Definitely not the back
        Thanks for responding.
        I think it may be a more of a fuel manifold type of connector.
        Not sure<!–more–>
        #277300
        Thanks for your help. The part maybe an oddball part for that year only. I will keep looking.
