Home › Forum › Ask A Member › elgin questions or 2
  • #244351
    Joe Mott
      i just started looking into restoring a pretty nice elgin 1 1/4 hp. its been setting for decades. i gave it a quick compression test and after a couple pulls got it to 60 lbs. what should i be getting for that motor? also i been looking for a carb for a week now i can not find a md a1 anywere. cant even get a re[ly from many inquires maybe i should walk away from this one?
      #244430
      Joe Mott
        well thanks anyway, but never mind i jumped into it anyway
        • This reply was modified 5 years, 3 months ago by Joe Mott.
        #244439
          There should be plenty of Elgin parts “out there”, so keep looking for a carb.
          Looks like the gas tank is in pretty good condition.
          Guessing it will run on 60 psi, but perhaps not a slow idler………
          time will tell on that one. I have a few Elgin’s, but none as small as yours.
          Regardless how it runs, it should be a worthy project, if for no other
          reason than it will look “cute” when all fixed up.
          ronandvanessa
            Looks great. 60 will run. Likely will come up after some run time.
            #244483
            Joe Mott
              thanks guys i did some filling on the tanks dents primed it and started cleaning her up some. i will keep looking for that darn carb!
              #244485
                Your little 1-1/4 hp Elgin appears to be the only model outboard that used the Tillotson MD-1A
                carb. There’s lots of MD carbs though. I wonder if a different one would work until
                you find the correct one?
                Joe Mott
                  i read were you could use a md a55 but something had to be done to it? a1 kit maybe?
                  #244536
                  jim-moffatt
                    Any MD carb from any early Elgin single or small twin will probably work and should be worth a try.
                    #244546
                    Joe Mott
                      wow thats good info thank you
