Home › Forum › Ask A Member › Elgin Outboard Service Manuals?
  • #268802
      Is there such a thing, or does anyone have, an inclusive Elgin shop manual?
      I’m working on a
      1951 Elgin 7.5 hp, Model 751
      Sears Model number 571-58751
      Currently, I’m wondering how to remove the upper crankshaft roller bearing
      from the cartridge, to get at the crankshaft seal, without harming the roller bearing, as it
      seems okay. It would be nice to be able to remove the bearing without
      ruining the seal, at least until I can get a bore measurement to see if I
      can find a replacement seal.
      I’ve tried heating around the bearing with a propane bottle torch and slamming
      down the bearing cartridge on the workbench, but see no movement of the bearing.
      There appears to be no way to use an inside bearing puller, nor can one get at
      it from atop with a punch.
      I have a general parts diagram that shows the bearing cap / cartridge, but it appears that it
      was sold with the bearing and seal as an assembly, as the later are not shown
      separately.
      Ideas, or a shop manual most welcomed. Thanks.
      DSCN5369
      DSCN5368
      Elgin-twin-powerhead-later-style-diagram
      • This topic was modified 3 years, 12 months ago by Buccaneer.
      #268836
      HARRY D. NICHOLSON
        The service manuals I have don’t mention disassembly or assembly, only how to remove/install as shown here.  If the bearing is meant to come out, I would heat it with a propane torch until it starts to smoke, and then drop it squarely onto the end of a short pipe held vertically in a vise.  The pipe needs to be the size which gives the bearing a place to go, and put a rag into it to catch the bearing. Elgin007
        Elgin006
        Dropping it onto a bench won’t do anything because it appears that the bearing is flush with the cage surface. The bearing needs clear space to drop into.   The sleeve tool is part number T-888.  If your serial number is below .18286 and your flywheel weighs 4 pounds, you may need the 6.25 pound flywheel if idling is poor.
        #268843
          I would try the heat/support/bang method a few more times, first, maybe trying to let some thin oil or WD-40 wick in between the bearing and the housing, before hand. Then, if that didn’t work, if it were me, I would measure the OD of the bearing and see if it’s bigger than the OD of the mag support part of the casting. If it is, then I would measure exactly where, then drill two holes 180 degrees apart, into the housing from the top, right above the OD of the bearing. Maybe 1/8″ holes. Then the idea would be to heat and support the housing, and use an 1/8″ punch to tap the bearing down, alternating between each hole. If that ended up being successful, then I would tap the holes (8-32?) and install a couple of shallow set screws with Loctite, to permanently close the holes.
          This is all speculation, of course. My co-workers tell me I think outside the box. Sometimes it works, sometimes it doesn’t.
          #268845
            Harry and Bob, thanks for the interesting replies.
            When I heated the bearing cap and slapped it on the workbench,
            I did so on the edge of the cap, so the bearing didn’t hit.
            Second try, I put the cap over the opened vice jaws
            and smacked the cap with a big plastic hammer.
            I guess I’ll get more aggressive with the heat and not
            worry about the seal.
            Interesting about the flywheel weight….. my serial number
            is 2750, so out of curiosity, perhaps I’ll weigh my flywheel.
            Bob, I’ve used your “out of the box” idea for something
            similar once, but can’t remember on what……. perhaps
            you helped out on that one as well!
            Thanks!
              I got out the big guns torch this morning and had the bearing out
              of the case in about 5 minutes. I straddled the bearing with
              the vise jaws and got out the big plastic hammer again.
              The seal didn’t even go up in flames, but a new one will
              be needed. I was able to punch the seal out from above.
              The top and bottom seals happen to be the same Garlock 139,
              .750 shaft, and 1.250 OD x .320 thick.
              Hopefully I can source something that will work.
              Still battling one stuck piston ring before the powerhead goes back together.
              DSCN5370
              DSCN5371
                Buc – looking at my National Oil Seals book, their 6835S seal is a close fit at .750 x 1.250 x .312 thick.
                1982 Evinrude 25hp
                #268863
                Monte NZ
                  Well done Buc!…..I like billw’s method……. I think that would work well!
                  #268874
                    Thanks Bob,
                    I found some seals by looking on the SKF catalog online, and ordered them this morning,
                    and they were the same thickness.
                    They were SKF 7465. I believe that they were advertised as seals for a Ford power steering unit.
                      Bobs idea is great, but it would not have worked too good
                      in this case, due to the size of the hub on the top of the cap
                      being the same size of the bearing OD below.
                        Thanks Bob,
                        Buc – OK, good you had another source.   I looked up that 7465 seal and found it also fits the power steering pump on a 1963 Studebaker if you need one!
                        1982 Evinrude 25hp
