Home › Forum › Ask A Member › Elgin 7.5hp replacement rod
  • #311937
    Will Steinbrueck
      US Junior Member
      I am a student trying to restore a 1961 Elgin-McCulloch 7.5hp (574.6008) and I snapped the thread wall on the rod. Apparently the torque spec is not 100 lb-in. Does anyone know where I can get a new rod/rod-piston assembly and also where I can get reliable torque specs? I have had a very hard time finding resources for this motor.
      #311950
      RICHARD A. WHITE
        Torque specs are pretty much standard. Odds are horribly against you finding a new replacement, look for a donor motor and scavenge parts from there.
        Here is some info that will help:
        Based on typical small outboard specifications, connecting rod bolt torque for a 7.5 HP engine is often in the range of 100 to 150 inch-pounds (approximately 8 to 12 foot-pounds).
        Note: It is crucial to consult the specific manufacturer’s service manual (e.g., Evinrude, Mercury, Yamaha) for the exact model, as specifications can vary significantly.
        Key Considerations for Rod Bolt Torque:
        Measurement: Small engine rod bolts are often measured in inch-pounds, not foot-pounds. 150 in-lbs is equal to 12.5 ft-lbs.
        Lubrication: Threads should be lubricated with clean engine oil or assembly lube unless otherwise specified.
        Method: Tighten in stages (e.g., 50, 100, then 150 in-lbs) to ensure even clamping.
        Reusability: While some bolts are reusable, it is generally recommended to use new connecting rod bolts if available, as old bolts can stretch.
        Facebook
        Facebook
        +4
        General Small Outboard Rod Torque Tips:
        If the spec is missing, 100-150 inch-pounds is a common range for engines of this size, but starting low and ensuring the rod moves freely is essential.
        Ensure the connecting rod cap is oriented correctly, as they are often matched to the rod and not interchangeable.
        classicomctools@gmail.com
        #311963
        perrys
            I’ve posted 4 links to some parts suppliers that may be able to help you. However, because it has more than one link in it, it has been quarantined.  You’re going to have to wait till someone releases it.
            #312011
              Try Doug at douglas.penn@gmail – Twin City Outboard at http://twincityoutboard.com – GC Marine Salvage at   https://www.gcmarinesalvage.com – Langs Outboards at http://laingsoutboards.com/usedparts.html
              #313198
              Will Steinbrueck
                US Junior Member
                Since finding a replacement seems unlikely, does anyone have a complete powerhead I can get at? Again, 1961 Elgin-McCulloch 7.5hp (574.6008)? Thanks.
                #313438
                elgin2
                  I have a 571-58571 that’s locked up and a 571-58771 that’s a complete motor and is not stuck. Don’t know if the parts are compatible or not.
