Home › Forum › Ask A Member › Elgin 6hp water pump
Viewing 1 post (of 1 total)
  • #2792
    james-davis
      replace water pump with a new impeller, coils with OMC, started up in water, probably first time in twenty years, would not pump water, pulled apart and rubber sheared off brass sleeve on impeller, did I do something wrong I don’t know about, old impeller was rotted away. lot of oil around impeller, probably seal problem, didn’t look bad , no play in shaft. Jim
