Home › Forum › Ask A Member › Elgin 1946/47 571.58301 1.25 Hp Air cooled, need a Piston, rings, rod assy.
  • #294666
    Bob Foscato
      Hi, hoping someone has or can help find this:
      Sears/Elgin made by West Bend 1946/47 571.58301 1.25 Hp Air cooled, need a Piston, rings, rod assy.
      #294698
      MHarrington
        I have the same motor and I needed the same parts (except the piston), piston rings (link https://www.ebay.com/itm/170930945421?var=470208408843 ) you need a 38 X 2 mm (1.496 X 0.079 inch) that is the size I needed should also be for you because they are the same motors and year frame, for a connecting rod I can’t really help you there, mine snaped in half and I had a friend weld it after we straightened it (still works fine).
        #294702
        JOSEPH BRINCAT
          Bob,  that is a pretty common motor to be found at our meet swap & sell events. If you aren’t in a hurry, just keep an eye open for a parts motor.  Now, an issue could be your location. Are you near any of the chapter meets?
          #294722
          Bob Foscato
            I’ll keep this in mind, Thanks.
