Home › Forum › Ask A Member › Electric start for 1969 Evinrude 25 hp
- This topic has 8 replies, 3 voices, and was last updated 10 years, 1 month ago by
amuller.
September 11, 2016 at 2:38 am #5219
I would like to install electric starting on this as I am pretty sure my mate will not be able to pull start it. There is already a ring gear on the flywheel but neither shop.evinrude nor marineengine.com shows an electric starting version. I don’t need help especially with the electrical side–that’s simple enough.
In searching online I find considerable discussion and disagreement on what brackets work to mount a starting motor on these.
I have some sheets for an electric starting kit for a 1968 18 hp. The bracket is called out as 308482 and the starter motor as 376850. Is this what I want?
Any guidance much appreciated.
September 11, 2016 at 9:19 pm #43831This was a frankenmotor purchased for $60. Three different colors …. and no hood. I wasn’t really expecting it to run as is but it does. This motor is at the upper limit of what I can hump around, and at the upper limit of comfortable manual starting.
And if anybody has a hood….I probably don’t really care whether it’s Johnson or Evinrude, neither have inspiring styling.
September 11, 2016 at 9:33 pm #43835September 11, 2016 at 10:51 pm #43841So do all the 22 cu in motors use the same bracket and starter?
September 11, 2016 at 10:53 pm #43842To the best of my knowledge, they do. With reservations.
EDIT: Well, I dunno I think the bracket was modified to hold the solenoid when the junction box was eliminated (??)
September 11, 2016 at 10:58 pm #43843So do all the 22 cu in motors use the same bracket and starter? I took one from a 57 18 hp and used it in a 72 25 HP Without any problems, that being said my guess is it should work…. I do know the starters from 1957 all the way through 1978 are the same, you can buy the new starter at discount starter and alternator for about 70 bucks 😎
September 11, 2016 at 11:52 pm #43849These kits, for all they cost, apparently don’t have a choke solenoid. So they are to electrify tiller motors, not for remote control…. I think I know what to look for now. Probably about any 22 cu in starter and bracket can be made to work.
September 12, 2016 at 12:41 am #43854The early 15hp motors looked similar but the brackets were different because they were for 6V starters. Just sayin, be careful they may not be what you think.
September 12, 2016 at 1:27 am #43860 -
