Home › Forum › Ask A Member › Early Johnson Mystery
- This topic has 21 replies, 8 voices, and was last updated 1 week, 3 days ago by
Tubs.
October 21, 2026 at 4:11 pm #330369
Like Tubs said .. if it’s #14-24 don’t loose it. When the subject of the old obsolete ASME/ American Standard thread sizes come up , I feel compelled to post the old size chart in the public interest. Please note the clone size proximity of several number sizes to our now common 1/4 ”
October 21, 2026 at 8:35 pm #330387FWIW, there is an industrial tool supplier in Michigan that carries hundreds of threading tools that can produce about any thread you can think of, including these oddball #14-24 TPI drain plugs. Its the same place as I bought the 10-30 tap and die for making the Johnson rope sheave plate screws that get the slots mucked up (or lost by somebody else, but not you) so often. As soon as I can find the last receipt from them, I’ll tell you the name of the company.
PM T2
October 22, 2026 at 11:56 am #330405October 25, 2026 at 10:15 pm #330530October 25, 2026 at 10:39 pm #330534
Pretty sure its 1/8-27 NPT Pipe. A hardware or home improvement store should have them. Cut the head off and slot it. If it doesn’t stop and goes all the way in,the plugs in the past have been over tightened and enlarged the hole.
ExampleA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
October 26, 2026 at 8:04 am #330545Wow, thanks Tubs! I probably should find a bronze plug for this bronze lower unit.
October 26, 2026 at 10:28 am #330552
Brass ones are available but be sure to check to see that its solid. Cut the top from a hollow one and your going to have a fairly good leak.
October 26, 2026 at 12:10 pm #330554Just to reiterate, both David K and I are looking for a starboard side cylinder for an early A model Johnson. I would also consider a complete powerhead.
thanks.
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
October 26, 2026 at 3:32 pm #330559Just to reiterate, both David K and I are looking for a starboard side cylinder for an early A model Johnson. I would also consider a complete powerhead.
thanks.
I plan to run mine as a single until I find that starboard cylinder. Might cause the boat to pull to the right?
October 27, 2026 at 10:35 am #330581It won’t be the first time. This was offered for sale on eBay over 30 years ago, when there was only the Green Board. I wish the pictures were better to get a better understand of what was going on here but eBay pictures weren’t the quality or the size they are today. I saved it because I found it interesting, showed some imagination, and its the kind of thing I would do. (boathouse repair) Someone on the board called it a “Twingle!” When I posted it the first time one reply was, “What did you post the piece of junk for?” I guess it isn’t for everybody.
