Home › Forum › Ask A Member › Dumb Cotter Pin Question
  • #295474
    LARRY CATON
      The prop shaft cone/nut on my ’56 FD-10 needs a new cotter pin.  5/32″ is too fat, 1/8″ feels loose.  I put a 9/64″ drill bit in the prop shaft hole and it fits perfectly.
      I can’t seem to find a 9/64″ pin anywhere.  So the question is, does it matter?  Should I just use a 1/8″ cotter pin and pull the head in as tight as possible?
      I also don’t know if the nose cone/nut needs to be torqued, or just snugged up and pinned.
      Thanks!
      1956 Johnson 15 Hp, FD-10
      1957 Johnson 5.5 Hp, CD-14
      1958 Johnson 5.5 Hp, CD-15
      #295475
        can you elaborate a bit… 🙂
        #295513
        LARRY CATON
          Wow!  My paragraph vanished! LOL
          The cotter pin in question is for the propeller cone/nut on my FD-10.  A 5/32″ pin is too big, and a 1/8″ feels loose.  The hole in the prop shaft perfectly fits a 9/64″ drill bit.
          I can’t find a 9/64″ cotter pin anywhere online or at local hardware stores.
          Should I just tighten the cone until it’s snug and make sure the 1/8″ cotter pin’s head recedes into the cone?
          #295524
            the cotter pin….  even if smaller will do fine   it just stops the rotation of the end cap  so there is no  big strain        you have no choice other a  piece of galvanized  hay wire to lock it in place  or thread the hole and use   a bolt and lock washer
            #295528
              Email me your address at old.days@yahoo.com  and how many you think you will need and I’ll send you some.
              Pin
