Home › Forum › Ask A Member › Duel Line pressure tank diaphram help needed
  • #285029
    huntleybill
      I’m restoring this tank and I need to replace the diaphragm. I have attached a pic. I need the top one but all I can find is the bottom one. Is there a supplier for these? Please advise. Thank you
      Bill
      diaphram
      #285032
        376987 (1957) diaphragm with riveted support washers was replaced by 0377327 kit which updated it to 1958 style with different push button and support washer.
        0377327
        #285034
        Dale
          Wow! ya learn something every day.  I have a bunch of those tanks and every one I have with that metal washer on it is held on with a small nut and lock washer.  I have just punched a hole in the diaphragm and it was good to go. Bill I could find you a push button with a nut on it if you want.   PM me if you want to do that.
          dale
          #285038
          Steve D
            Bill, I have that mushroom shaped button and support washer that you need to upgrade, allowing you to use that new diaphragm you have. Here’s my email if you want to get a hold of me.  sdpiazza (at) aol (dot) com
            377327-upgrade-kit-for-push-button-on-dual-hose-tank
            #285059
            Dale
              Bill it looks like Steve has you covered.  I have more tanks with silver buttons than I originally thought.  I like the pressure tanks but they can be tricky to repair.
              dale
              Ya can’t buy happiness but you can buy another old kicker…. that’s almost the same!
