Home › Forum › Ask A Member › DT 37 Johnson water pump
- This topic has 11 replies, 4 voices, and was last updated 5 years ago by
GARY SMITH.
August 10, 2021 at 7:04 pm #244646
I just got a DT37 Johnson running and now need help to fix the water pump. I’m not sure what comes apart to do the change. I don’t have a manual that goes back that far and I’d rather not take something off that I don’t have to.
August 10, 2021 at 8:04 pm #244655Here’s at 1940 version taken apart, should be very similar.
Getting the pump discharge line disconnect was the hardest part if I remember
correctly.
Sometimes the pump plunger wears out, the came on the prop shaft, springs
break, and the check balls can deteriorate, plug up, etc.See attached manual below.
1939-40-Johnson-5-hp-LTATDT-Parts-Manual
August 10, 2021 at 8:21 pm #244668
If it doesn’t pump anything at all start with
looking for a stuck check ball.
August 11, 2021 at 7:41 am #244714Thanks so much. I don’t usually work on stuff this old and have been putting it off so long I don’t even know where I got this one. I will dig into it today .
August 11, 2021 at 12:51 pm #244719I took the pump apart and the small check ball was stuck so thanks for the tip. Now does the lower unit get marine grease and do I pack it in or just coat the gears and prop shaft ? I have to make a new gasket for the housing as I was a little over zealous taking it apart. Other than that it looks ok except for a pretty good wear mark on the back end of the prop shaft.
August 12, 2021 at 8:54 am #244745August 12, 2021 at 9:32 am #244748ok thanks. I have a small tub of 105 that I had for the waterpump on my chris craft . Unfortunately that boat was pretty much destroyed in an accident on the road a mile from my house. I got the boat back but don’t have the heart to do it all over again after spending two years on it the first time. I hope to find a new home for it this fall.
August 13, 2021 at 10:36 am #244818My next issue. I’m thinking jb weld applied on the outside of the crack to seal it. Any other methods that you may have tried ?
August 13, 2021 at 10:38 am #244820Next issue is this broken ear. I’m thinking jb weld on the outside to seal the crack ? Any other methods you may have used ?
August 13, 2021 at 3:56 pm #244836JB Weld won’t hold it; when you tighten the screw it will pull the tab away from the rest of the casing. I’d get it welded by someone who does aluminum welding. JMHO, and similar experience. NABMD
