Home › Forum › Ask A Member › DRIVE/SHEAR pin for 6hp late 60s
  • #295330
      are 3/16 brass “pins”    cut  from a 3/16 brass rod   ok as drive/shear pins  ?
      #295331
      Dale
        Works for me!!
        dale
        #295339
          I cut  up some  1.380 inch pins…. metal  seems stiff enough and brittle enough after a few nicks with cutting pliers.  🙂
          I’ll just tape 2-3  and cotter pins on the handle 🙂
          #295343
          LARRY CATON
            I’m so glad you asked ‘cuz I had the same question about my ’56 FD-10.  Now to scrounge for 3/16″ rod!  LOL
            1956 Johnson 15 Hp, FD-10
            1957 Johnson 5.5 Hp, CD-14
            1958 Johnson 5.5 Hp, CD-15
            #295358
            ED
              Shear pin p/n and material – Data from OMC Service
              6hp     307949   3/16    1 3/8      Stainless
              15 hp   203663   3/16    1 3/16     Stainless
              51/2    302333    3/16      7/8        Monel Rod
              Ed Elliott
              #295361
                I had a broken shear pin on a mercury Mark 7  when I was a kid. I did a McGuyer on it. took the 3 pieces of shear pin rearranged them and it got me home fine
                #295362
                  CDN $4.99/foot for  brass rods.  with 2 feet I have enough to last me till I croak .
                  #295363
                    I use a tubing cutter to cut them.
                    #295365
                    reivertom
                      Thanks for posting this, I’ll need some spares in the near future.
                      #295367
                        snip and grind the ends flats.. works ok     1.380 inches fits perfect in the prop slot
