Home › Forum › Ask A Member › Drain one tank into another? EDIT
  • #34775
    jerry-ahrens
      If it’s a pressure tank, you won’t need to siphon it, just use the primer button to get it started. Might take a while though. As for me, I will never siphon gas by mouth again, even if I have to walk out of the dessert! Last year I did that, as I have done for years, but this time I ended up swallowing a 24/1 mix. I seriously considered going to the emergency room. I belched gas for 2 or 3 days and was well lubricated. I do like the jiggle siphons… they work well and are quick.
      #34779
        This is by far the best product for siphoning gas! Much better than a jiggle siphon. Super easy, and pumps quick
        http://www.canadiantire.ca/en/outdoor-l … nt=Default
        I have 2 of them. 1 at home, 1 at the cottage.
        #34786
        beerman57
          I didn’t want to have to pull the connector off, gas siphoning 101 – wrap a rag tightly around your siphon hose and hold the rag tightly against the tank opening, obviously with the hose down in the gas. So that’s what I did this afternoon, BUT the spring in the fuel connector isn’t strong enough to push the brass end up into the Oring.
