Home › Forum › Ask A Member › Drain hole or ding?
- This topic has 8 replies, 6 voices, and was last updated 11 years, 6 months ago by
legendre.
April 24, 2015 at 11:48 pm #1315
I have a mid-60s Evinrude 60 hp motor that I just got on an old boat and there is a hole in the lower unit that does not look like a factory drilling. It was suggested to me that it may be milled. Does anyone have a mid-60s Evinrude that they can go do a visual on for me? It is the hole right above the phillips head screw near the oil fill plug on the port side of the lower unit. Is there a diagram anywhere of the various water weep holes?
April 24, 2015 at 11:52 pm #14674Not sure…this diagram does not really show. Search for other years?
http://www.marineengine.com/parts/johns … p-standard
April 25, 2015 at 12:09 am #14677Darn it, I’m the guy that told you that is a milled drain hole. To prove it, I just went out and took a picture of one. Now my computer is acting up. Gr.r.r.r. When I get it, I’ll post it.
April 25, 2015 at 12:22 am #14679April 25, 2015 at 3:50 pm #14733Definitely a ding. It could let water into the gearcase if it opens to the section where the shift rod is.
April 25, 2015 at 4:13 pm #14735Im not sure why they are there, but every V-4 of the era has one that I worked on. I’m with Frank on this one. It is a machined mark for some reason. The oring you see in the parts break down seals the complete area and that little notch is outside of the oring.
Dan in TN
April 25, 2015 at 7:14 pm #14751April 25, 2015 at 8:25 pm #14758Frank… I owe you a beer. Yes I did post this question on another forum and you can see why I had my concerns. That hole does NOT look original but your picture verified it for me. Thank you for taking the time to post that pic. I looked at lower unit pics on Ebay and google images and could not get a clear shot. Thanks!!
April 26, 2015 at 2:05 pm #14787Nice feature. Making sure that hole is clear should be part of the winter storage procedure.
