Home › Forum › Ask A Member › Does it even matter ?
- This topic has 12 replies, 8 voices, and was last updated 10 years, 4 months ago by
wedgie.
July 3, 2016 at 2:42 am #4652
I’ve found more than one of these where the locator pin is broken/worn off flush where the rear prop bearing sits. Does it matter if the rear 0303380 – Bearing can spin a bit ? In the past I’ve drilled into the locator pin and pulled it out,luckily without damaging anything. I don’t want to risk doing this again if it is unnecessary.
July 3, 2016 at 4:24 am #39511They don’t ware down. They get pushed down when the bushing is not lined up properly. If there isn’t room to go down, they can distort the bushing causing binding and leaks. Any movement of the bushing will cause ware in the softer aluminum. That is the reason they are pinned. If broken off below the surface, drill a new hole to the side of the old and put in a new pin. . . . . 😉
July 3, 2016 at 12:48 pm #39521X 2 on what Garry just said. Getting the pin lined up in the front bearing is important. If the bearing pushes the pin in like that, it will put pressure on that point in the bearing and may cause it to heat up while running, because of the pressure.
I believe that pin is also to set the oil hole in the bearing, in line with the oil passage in the gearcase too.July 3, 2016 at 6:43 pm #39537Is it possible to drill it and use a screw extractor to get it out, or is it too small for that?
July 3, 2016 at 7:17 pm #39538Im not really sure why they make the hole that deep! I have extracted them with left hand drill bits, or screwed in small sheet metal screw then pried it out. Couple I couldn’t get it I did as stated above, and drill a new hole beside the old one.
July 4, 2016 at 12:45 pm #39569I can imagine drilling into that pin might be tough. Those are tool steel, aren’t they? If you are lucky enough to dril into it, it should come out fairly easy with an extractor…..unless someone locktited it.
July 5, 2016 at 3:09 am #39619I ‘ve never worked on that lower before but I know what I would do..Install another pin along side the other useless one. Drill shallow hole in bushing for new pin. Silk purse from sow’s ear…
Golly Gee Whizz..I see now I stole ChrisP idea..
July 5, 2016 at 3:11 am #39620…or see how far the old pin will drive down..might be able to put new pin on top..
July 5, 2016 at 3:22 pm #39633Unfortunately they won’t go deep enough for a second pin. Drilling and extracting is really the best option. You have to be careful about puting in a second pin, because you want oil to flow into that bearing. If the oil hole is cut off, then you’re out of business.
July 7, 2016 at 1:26 pm #39791What about putting a pin on the other half of the gear case? and just leave that pin in place. Drill a hole in the brass bushing 180 degrees from that one the drill a hole for pin in the skeg part of case and place a pin in it.
Joe
ps been thinking about that a couple days now
