Home › Forum › Ask A Member › Does anyone know the interchange numbers for these Lark III Bearings?
- This topic has 7 replies, 4 voices, and was last updated 6 years, 6 months ago by
mr-asa.
May 11, 2020 at 7:56 am #202715
The lower unit for my 40HP is bone dry and fairly rusty inside. I’m looking for new bearings but I am 100% against paying retail outboard prices for them.
After doing some searching, I’ve found one of the bearings, but not the rest
#17, 375761 Roller Bearing is a Timken 12580
$72 on Marine Engine (and similar price elsewhere) https://www.marineengine.com/newparts/part_search.php?part_num=375761
A more realistic price of $16 for the bearing can be found on Amazon. https://www.amazon.com/Timken-12580-Bearing/dp/B000BZAAW2Does anyone have the rest of the bearing part numbers?
Pics of the LU
https://i.imgur.com/texcLpl.jpg
https://i.imgur.com/LcLsqN8.jpgMay 11, 2020 at 8:05 am #202760Give ’em a good wire brushing. The numbers should be stamped on them.
May 11, 2020 at 11:34 am #202779307545 is a SKF 6304 NDH3304 or sierra 18-6037
May 11, 2020 at 1:14 pm #202784Give ’em a good wire brushing. The numbers should be stamped on them.
The only one that had any number was 307545, and the actual number was worn off. It had “Norma” and “ade in US” on it.
The remaining 3 (I think) are too small to have numbers on them
May 11, 2020 at 1:15 pm #202785307545 is a SKF 6304 NDH3304 or sierra 18-6037
Awesome. One more down. Thanks
May 11, 2020 at 2:27 pm #202792So, I’m definitely in need of 376858. I’ve been able to find the rest.
Does anyone have one?
Also, does anyone know the water pump and seal kit numbers for this?
1961 Evinrude 40 hp 35525May 11, 2020 at 4:27 pm #202808Water pump kit is 379775 for the entire kit including new housing or 379768 for the impeller kit only.
Seal kit is Sierra 18-2686 or GLM 87607
"Every time you remove a broken or seized bolt an angel gets his wings."May 11, 2020 at 6:16 pm #202823Appreciate it, Bob
