Home › Forum › Ask A Member › dimensions for 18-7117 / 303360 O ring
  • #5969
      Anybody have the dimensions…thanks
      #49794
      Leon
        What is this o ring for?
        #49796
          quote 1946Zephyr:
          https://www.amazon.com/Sierra-Internati … B001RI5YPK
          says:
          Sierra International 18-7117 Marine O-Ring for OMC Sterndrive/Cobra Stern Drive
          http://www.marineengine.com/newparts/pa … SIE18-7117
          says:
          Replaces OEM #0303360.
          18-7117 O-Ring
          Replaces: 303360, 25-35027
          I.D.- 1.046
          Width- .139
          Sierra Marine O-ring is equivalent to parts:
          303360 Evinrude Johnson OMC BRP
          25 35027 Mercury Marine
          9-76507 Mallory Marine
          Additional information about this part can be found on page(s) 296, 739 of the Sierra Marine catalog.
          (links followed below):
          http://www.marineengine.com/parts/sierr … -00296.htm
          Johnson Evinrude OE Part: 303360
          ID 1.060 (!!!)
          Width 0.135
          http://www.marineengine.com/parts/sierr … -00739.htm
          Mercruiser OE part: 25-35027
          ID 1.046
          Width: 0.139
          So….. If the Sierra part doesn’t fit quite right (as they often don’t) you know why!
          #49807
            Such goofy numbers. A (dash) -214 standard o-ring is nominal 1" ID x 1-1/4" OD x 1/8". Actual .984 ID x 1.262 OD x 0.139 wide. If these don’t seem right, the list can be found at https://www.mcmaster.com/#o-rings/=15nevkr
            #49809
              thanks I think AS215 would replace 18-7117 looking to save a few $$$ as ordering some parts is nuts .
              ex: O ring cord (spagetti is $2.47 CDN per foot ) Timken oil seals $6.50 vs $15 + shipping
