Home › Forum › Ask A Member › Did Yamaha use Johnson engineson some 3 Cyl.
  • #2710
    cannuck
      My neighbor has a bad 86 Yamaha 70 HP model 70 ETLJ 6H3L Did Johnson sell them some engines and are they the same His block is bad . New one on me
      #25175
      chinewalker
        No, they’re quite different…
        #25179
          Ha ha, that sounds perfect for another running thread. It sounds like somebody just can’t face the fact that Yamaha is not perfect, so they have come up with some cockamamie story to blame the power head failure on OMC. That’s beautiful!
          #25183
          cannuck
            No actually a so called mechanic told him that .
            #25191
            Casey Lynn
              Probably the first thing to do would be to trade in the mechanic, Sounds like a ten minute hero kind of thing to say to a customer.
              There are many direct copies of OMC by foreign manufacturers though. Trim systems are identical looking but it looks like they had the "negative" turned backwards when they made their version. Crankshafts will even fit in at least one V-block although that is as far as the similarity goes on that example.
              Probably the best example was the year that Suzuki decided to display their upcoming V-6 outboard in a glass case down at the Miami Boat show. Was asked to go over and take a look at it and found the raised OMC logo embossed in the transom brackets and trim system on that engine. We immediately called Suzuki who removed the engine by the end of the day. Got a personal apology from the president of Suzuki on that one which I thought was a pretty darned good thing for him to do. Think I still have that letter somewhere in my files.
              #25215
                Yamaha is pretty good at copying other products and their three cylinder 70 horse is a perfect example. While not identical to the OMC motor, there’s enough similarities to see the resemblance. Remember their 650 twin motorcycles? At first glance they could be mistaken for a British Triumph.
