Home › Forum › Ask A Member › Diagnosing no spark issue on 1992 mercury 8 hp. 2 cycle
- This topic has 10 replies, 5 voices, and was last updated 2 years, 6 months ago by
JACQUES.
April 19, 2024 at 3:00 pm #287060
Hello. Would anybody here have Mercury technical knowledge regarding a no spark condition on a 1992 merc 8hp. 2 cycle model # oG20073 . Specifically Mercury step by step knowledge on how to check each component of the electronic ignition. There is no spark on either of the 2 cylinders. I do not have a Mercury specific shop manual and a Clymer manual just does not make it. Thank You Bill,
April 19, 2024 at 5:58 pm #287075did you check utubes maybe somebody fixed one … when did this start happening.
you have a electronic ignition so anything goes… switch box trigger
dual plugs..coils wires likely did not fail together so you are back under t e flywheel. kill switch could cause a problem
see page 76 -77 in this doc. .. all this requires testing skills with thenecessary eqpt. (VOM)
CDI Troubleshooting Guide – 2012.pdf (cdielectronics.com)
this is kind of a modern engine 🙂 Hopefully experts will chime in … try alsos the IBOATS site for help .
see video on a Mariner problem to show what is involved here the CDI switch box is frequently the culprit has tested in this video
8 hp Mariner – Diagnosing a bad CDI with an Ohm Meter “No Spark ⚡️” – Part 1 of 2 (youtube.com)
April 20, 2024 at 9:42 am #287086Yes, I know it’s kind of a modern engine. Only 32 years old. (It makes me feel old cause I think it’s brand new). I live in the Cleveland Ohio area and there are not many marina stores left around here for support for engines of this era. Plus, parts are very expensive to just replace parts you think are bad. I just thought it was worth a try here that someone was familiar with this era of motor. Regards Bill,
April 20, 2024 at 10:46 am #287088check in on IBOATS folks .. user RACERONE is probably the top tech and may answer your questions or try the search utility
Mercury & Mariner Outboards | Boating Forum – iboats Boating Forums
anything special happened before the failure ? Did you try a kill button running at high rpms ?
what are your “electrical” testing skills ?
Dave Bernard here on AOMCI may pop in. he his the Merc man !
another site to look for help is Johns’s old mercury site . no certain if membership is mandatory for questions but that is where Merc folks hang out 🙂
JohnsOldMercurySite – Index page
April 20, 2024 at 11:29 am #287092this may solve the problem
April 20, 2024 at 6:56 pm #287109Hello Crosbyman. Already talked to Dave Bernard. He said too new for him. I have talked to him before he is a nice guy. Motor was running good and very reliable. Shut it off normal and the next time would not start. It has a couple of kill switches on it and I was told there might be one more. Too much safety for my likes. But it has been a reliable motor for years. I am sure the problem will reveal itself eventually. Thanks again. Bill,
April 20, 2024 at 7:54 pm #287112ok good luck with the motor keep us all in the loop on the aches of your “new” motor. 🙂
just fyi the phase maker ignition (Thunderblot) using points would fire on points CLOSING contrary to magneto convention.
the CDI circuit was known to blow when the kill button was used when RPMS where high. With more modern CDI like yours with no mecanical points (uses a trigger pulse coil) I am not educated enough to know if the CDi could … be kill if interrupted at higher rpms.
If you are able to measure specs on the trigger and the stator as per the Video and the CDI book I strongly suspect the CDI box itself.
thankfully they don’t seem to expensive on Amazon compared to OEM at 300$
fyi bed time reading 🙂
https://wrcoutboards.org/wp-content/uploads/2021/02/The-Phase-Maker-CDI.pdf
Microsoft Word – Generator Coils Explained.doc (wrcoutboards.org)
April 20, 2024 at 11:46 pm #287124Disconnect the kill wire from the switch box, it should have a black wire with I think a yellow tracer.
Doubt it is the coils.
If still no joy then it is something under the flywheel or the switchbox.
April 21, 2024 at 11:37 am #287154Hi,
I’m not a Mercury trained tech but I was working on a 1981 25HP Mercury the other day and it appears to have an ignition system essentially the same as your 8HP.
Since you have no spark on either cylinder….I would feel that you can rule out the coils. It would be unlikely that both of them have failed.
I have attached some data. Also the CDI troubleshooting PDF for the Stator.
Most of the tests require only a VOM; the stator voltage tests are harder to do unless you have a test tank and can run the engine at WOT with a DVM attached.
As Michael stated above…..the very first thing you want to do is disconnect the kill switch at the switchbox. That could very well be the problem.
April 21, 2024 at 2:04 pm #287165CDI Electronics has a trouble shooting guide that might help you out. I’m sure they make the parts you need to get your future vintage outboard running. www.cdielectronics.com Google it and you will see the trouble shooting listing to click on.
