Home › Forum › Ask A Member › Dents
  • #4006
    Goman
      Anybody have any luck getting out dents like this working from the inside?
      Thanks
      Glen
      #34628
      shoestringmariner
        no experience with those specifically, but something like that i would tackle by tacking or braising rods on the dent area, pull them and then smooth out over a mandrel. Is the long tapered end open? (if i couldn’t hook something inside the large end and press it out)
        #34634
        opposedtwin
          Tubs will chime in soon. He’s a master.
          #34640
            #34642
            Goman
              The long tapered end is open at the end. It’s a thinner aluminum than the fuel tanks so I was hoping it would be more doable. I have the low temp aluminum rods maybe I can pin it then pull up on it? Then after I try a few more things and waste the day I can send it to Tubs guy. 😀
              #34650
              wedgie
                Goman
                  Wow. The one after that shows you how it’s done. Just gotta find a tuba repair place now. 🙂
                  https://www.youtube.com/watch?v=4vAM8_BEz7g
