Home › Forum › Ask A Member › Dents on the Motor Cover – Bondo ?
  • #265737
    RickV
      Hi, I am on my 1st partial restoration, just joined the club a few days ago.  My Vintage  (1950’s I think) Mercury 5 HP motor has some dents on the cover.  What is the preferred method to cover these up ?
      Any help appreciated,
      Thank you
      • This topic was modified 4 years, 2 months ago by RickV.
      #265742
      todd281
        If the dents are not too large, I use steel stick two-part epoxy. It come in a stick form and to use it you cut off a piece and kneed it to form a gray putty. Clean and rough up the housing and slightly overfill the dent. It dries in about 1/2 hour, ready for final shaping and sanding.  I never had much luck with Bondo type products, but that is just me. I have seen where others have used it and it looked pretty good. Good luck and welcome to the club.
        #265743
        RickV
          Perfect,  Thanks Todd , will give it a try
          #265744
            Rick also if you want to spend the money, take it to an Auto body shop.
            #265756
            bob-d
              Rick, I have used Bondo, and or JB Weld with good results. I fill deep dents with the JB, and then a layer of Bondo on top. With smaller dents, I just use straight Bondo.
              I rough up the area with a coarse sandpaper, and then make sure it’s good and clean. (brake cleaner).I put the Bondo or JB Weld on, and then use a palm sander for large areas. Use 220 grit to start, then 400. After it’s smooth I hit it with glazing putty, and  sand again with 400. Then a coat of self etching primer. After the primer dries another round of sanding with 600, and your last coat of primer before topcoat paint.
              This is the method I used on the 10HP Johnson below. It has worked well for me.
              I’m sure others will chime in.
              Bob D
              0F3381C6-1B1E-4E58-8F68-BCCAB8723947
              #265761
              RickV
                Great information Bob,  Thank you. Beautiful Johnson motor,  Thanks for sharing.  I bought a total of 4 antque motors in the last week, crazy how this hobby can hook you.  I can see my garage being filled up with these motors very quickly, sheesh.
                #265762
                tinkerman
                  Stay with it!! And yes it’s addictive.ive got more than I need and always looking for more haha
                  It's a jungle out there.
                  #265772
                  RickV
                    Thanks,  yes , neat hobby, wish I started sooner.
                    #265773
                    RickV
                      Thanks Dave
