Home › Forum › Ask A Member › Dents in aluminum tank
- This topic has 15 replies, 12 voices, and was last updated 11 years, 5 months ago by
Anonymous.
May 15, 2015 at 12:12 pm #1498
Any Suggestions/tricks on getting dents out of Aluminum Neptune tanks I don’t want to paint it.
May 15, 2015 at 12:35 pm #16031Outboarder had an article..many many years ago cut a patch out of the tank in a location that is hidden by the flywheel, and pound the dents out.. re-weld patch back in place. It will take time and patience but results can be amazing….
classicomctools@gmail.comMay 15, 2015 at 12:56 pm #16033thanks Richard
May 15, 2015 at 5:42 pm #16045Anonymous
DeltonMike
Welcome to the forum.
Here’s some links to a couple of video’s from member Tubbs working a couple tanks.
https://www.youtube.com/watch?v=JYFQOiSc8UYhttps://www.youtube.com/watch?v=tnJAbxWInHw
Good Luck with Your tank.
Steve A W
May 15, 2015 at 7:47 pm #16047Here’s a bit of info from an old Johnson Service Manual.
May 15, 2015 at 9:10 pm #1605340 lbs?????!!!!!!!
classicomctools@gmail.comMay 16, 2015 at 4:22 am #16088quote Richard A. White:40 lbs?????!!!!!!!Yes.. 40 lbs!!!!!!
Or so they say, lol. I don’t see why an otherwise-solid tank couldn’t withstand 40 psi.. but dang, wear some protective gear, including heavy-duty eye and ear protection. The freakiest part for me, is the ‘playing of the torch’ flame.. aluminum tends to get really soft, really quickly.. and not in a very controllable fashion.
May 16, 2015 at 8:38 am #16092My thoughts are at 40 lbs and if you don’t have ALL sides and ends blocked in..this thing will look like a balloon. Especially after you add heat and soften the material. Jay Walls when holding a workshop, explained using only 9 lbs, and went so far as to say, Not 8, not 10 but 9 lbs of pressure. I personally have not used air.
regards
Richard
classicomctools@gmail.comMay 16, 2015 at 1:06 pm #16098A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 12 months ago by
Tubs.
Tubs.
May 16, 2015 at 3:32 pm #16104Tubs that bench is cleaner than my socks. I didn’t get my family OCD gene. Lol
