Home › Forum › Ask A Member › Decal Replacement Question
  • #3934
    david-bartlett
      I am considering putting a new decal on the tank on my Bendix twin. The decal that is available is a water slide type. My question is will this work on the bare aluminum tank, or should the tank be prepped somehow first. I would probably clear coat the decal area when finished, but will take any and all advice. Thanks.
        #34055
        david-bartlett
          Tubs,
          The compound curve issue may prove to be a challenge. Gotta try though.
          Thanks.
          #34065
          jim-moffatt
            Martin SIG leader Russ Larsen has experience applying water slides to compound surfaces. The rear Martin decal is applied to a double compound surface. His web site may have info or call him he is very helpful.
            #34069
            david-bartlett
              Jim,
              Thank you for that info.
