Home › Forum › Ask A Member › Deadman controls
  • #256908
    Mallett
      What’s the deal with these deadman throttles? They have to mount on the port side of the boat? Is that because the guys that made them right handed, wanted to have there dominate hand on the steering wheel? Just asking.
      #256911
      RICK EICHRODT
        The deadman or “racing throttle control” was developed for hydroplane and runabout racing boats.  You see, when raced, most if not all the courses only had left hand turns.  Having the throttle on the port side also gave the driver something to hold on to when making those fast turns.  He can hold on to the throttle and also the steering wheel.  The “deadman” part of it was that the throttle lever was spring loaded and if the driver let go of the handle (like being tossed out of the boat) the throttle would spring back to idle.  Most racing motors back then, and now, call for a closed butterfly which means that when brought back to “idle” the motor would shut down due to the carb butterfly fully closing and shutting off the fuel/air.
        #257038
        modhydro
          While Rick is correct on the most common mounting.  Richardson throttles had the mounting holes countersunk on both sides so they could be used on either coming.  It was uncommon to see one on the right though.
          A friend of mine races the Indian River Marathon up in Michigan and has his throttle on the right side of his boat….
