Home › Forum › Ask A Member › Cylinder head shocking me 1957 35hp evinrude
Viewing 10 posts - 11 through 20 (of 25 total)
  • #52946
      My best guess is it is arcing across the outside of the plug, and across the surface of the paint to your finger. But I still think that is near impossible.
      #52948
      PugetSoundBoater
        If you applied a lot of paint to the head, the bolt shoulders may have not cut through the paint to provide a good enough ground , not providing as good a ground as you. Electricity always seeks the best,closest and easiest path to ground. Since you are testing in a barrel, Are your feet wet and standing on wet ground. I got a good zap with a timing light with wet feet.
        Your shock may be a combination of the two possible scenarios causes.
        Robbie Robertson
        #52951
        donsmarine
          try grounding the armature plate to the block with a jumper lead with alligator clips
          #52952
          sqrl42
            I applied three layers of paint and bolted over the paint.. So now it’s all coming together. yes i was standing in water with it in the test bucket.
            Runs great and idles smooth in the bucket.. like crap in the lake, like one piston decides to fire late.
            I had no problems before i switched the cylinder plates.. Plugs and boots are correct and good condition! Gotta be the paint i guess!
            I’m going to have to remove paint or ground out another way I guess, still learning a a lot about small engines and grounding, the hard way!
            #52960
              Well, I can fathom the slim possibility that the head is somehow partially insulated from the block due to excessive paint/sealer….But, if this was the case, I can understand that shock because you are helping to complete the circuit. But, following this scenario, the ignition wouldn’t be killed, only improved, because your body is helping to complete the ground circuit. Perhaps the primary side of the ignition is partially grounded to the mag plate. The mag plate is not well grounded on these engines, touching the block helps complete this primary short to ground which kills the engine…But, this would probably only affect just one bad cylinder’s ignition circuit….
              This kind of reminds me of a 2hp problem I had once. The mag plates on those OMC 2hps are pretty well insulated from the block with a plastic bushing, there is a ground strap that is supposed to complete the secondary circuit but its ground connection was weak/rusted.
              The only time I would get shocked was when I touched the aluminum throttle lever, I guess I was helping to complete the secondary circuit.
              #52986
              sqrl42
                ** Fixed shock**
                Had to remove some cylinder head bolts, sand off paint and replaced bolts. no more shocking!
                14′ Aluminum Boat, no gear.
                I’m still having problems with the engine running like it has no power at WOT, and out of no where it kicks in and I’m on plain at 28mph.
                When I slow back down, it bogs down if I try to throttle back up and starts to sneeze than out of no where it gets fuel and i’m hauling.
                Boat runs great at idle, easy to start.
                I’m having trouble with packing for low speed adjustment, could this be the culprit of the
                #52987
                  Sounds electrical. How old are the condensers? A set of new NGK B8S plugs might help to.
                  #52994
                    Does your flywheel have an inspection plate? If so, you might want to peek inside to see if perhaps the flywheel has chafed some primary wiring under there…
                    #52995
                    Leon
                      If you’re having problems on the lake and NOT at home in the test barrel, then your fault is under the flywheel. Cracked coils, etc.
                      #52999
                      lindy46
                        Yup, sounds like one cylinder is cutting out. Why did you replace the head? How is the compression since you changed the head? If compression is good, look under the flywheel.
