Home › Forum › Ask A Member › Cylinder head for RDE-17
  • #248119
    Jason Tucker
      Looking for 1955 part number 376336. Question is are there other part numbers that could be used?
      Need replacement Cylinder Head.
      Thanks
      #248125
      CHUCK
        Hopefully someone here will know the answer to your question. In the meantime….I see that there are currently a couple of those cylinder heads on ebay. Kinda spendy,,,,,
        https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=376336&_sacat=0
        If you have time; try posting a WANTED ad here in the free classifieds section. Probably a lot of them around and you might get a lot better price from a fellow member.
        #248210
        MIKE SIMS
          My ’68 Parts Reference Guide shows 592984 applies to your motor.
          common
          common2
          #248214
          MIKE SIMS
            And my ’72 Master Parts Price book confirms the supersession 592984 replacing 376336
            #248292
            retiredoz
              376336 is the casting number, which is what you can find on the part. 592984 is an ‘engineering’ part no, different because the head includes a couple caps on the central tube, hence an assembly. Other than a parts list, the only place you’ll find that number is on the box it comes in..
              The two numbers will usually coincide if the part is a simple (no components) part.
              Marineengine says they have a new one cheaper than Ebay
              • This reply was modified 5 years ago by retiredoz.
