Home › Forum › Ask A Member › Current thoughts on buying OMC “universal coils?
Viewing 10 posts - 1 through 10 (of 27 total)
  • #208415
    amuller
      I’m redoing the ignition work on a 1962 5.5 because the coils appear to be crap. This is from what I posted on the facebook page:
      “No noticeable spark but runs poorly. Coil secondary 4.62 k ohms upper (low?) and open on lower. I replaced these coils a couple of years ago and used new wires. Probably bought from Amazon. They are black plastic and marked 583249 and 18GZ-OA. So I can pretty much only conclude that these were bad coils. Any thoughts?”
      So where should I be buying coils? The price seems to have crept up noticeably and I don’t know where to get the German-made ones. How is Sierra quality these days? I’m too old and lazy to want to be doing jobs over again trying to save a few bucks….
      Thanks for any thoughts.
      #208425
        I’ve typically bought OMC/BRP coils from Marine Engine. Never had any problems with them. The German made Prufrex coils went out of production several years ago but you can sometimes find some for sale on Ebay. Haven’t tried the Sierra coils but I’ve read that fitment can sometimes be problematic.
        1982 Evinrude 25hp
        #208432
          I have only used cheapies on EBAY with no issues yet … not one bad coil physically or electrically
          #208438
          David Bartlett
            BRP for me as long as I can get them!
            David Bartlett
            #208443
              #208448
              amuller
                I took some condensers out of a ’69 25 hp Evinrude. They are 581419 and measure about .565 mfd. I’ve not seen these before and that seems like a high value for an ignition condenser. Anybody know what these are supposed to go in and what the capacitance is supposed to be?
                Thanks.
                #208450
                amuller
                  This has been one of those days when everything I touch is bad or goes bad. Took two German coils out of a motor that was incomplete but running. One has a secondary resistance of 27 k and the other 240 k. No cracks, no exposure to moisture….. No spark, no spark, no spark….Grrrrr
                  #208455
                  Steve D
                    Thanks.
                    I don’t know about the capacitance but those are the right ones for that motor. 581419 is part of Tune Up Kit 172523. This is the application chart on the back of the kit, not sure if the condenser is used on any other motors not listed.
                    172523-581419
                    #208461
                    amuller
                      Thanks. My Fluke meter can report capacitance, but I don’t think it’s a test under the higher voltage of operating conditions. And the reading of .565 mfd seems suspicious to me. So many condenser numbers and so few specs! Always more to learn….
                      #208465
                        If you can’t do a true leakage test on a condenser, then just assume it needs to be replaced. Anything else is just Christian Science.
