Home › Forum › Ask A Member › Cruise-a-day fuel tank Question
  • #4859
    fishbrick
      On the late fifty’s cruise-a-day tanks, are there two gaskets? There’s the one that’s sandwiched in between the top unit and the tank, but is there also another one in-between the tank and the lower unit?
      #41074
      RICHARD A. WHITE
        Look on this page, it may not be the exact one for yours, but should be very close…
        http://www.vintageoutboard.com/collecti … ems?page=2
        classicomctools@gmail.com
        #41089
        Steve D
          There is only one gasket. In this diagram the gasket 39 goes between the tank and the push button/handle assembly housing 35. The diaphragm 38 is sandwiched between that and the lower housing 22.
          image hosting no account
          #41125
            I’ve never had one apart (yet) but in looking at the diagram, where does #41 fit into the equation?
            Kirk
            #41134
            Steve D
              That’s the support that the whole assembly gets screwed on to. It goes underneath, inside the tank. It’s held on by 2 screws (20) and lines up with the rectangular and circular openings and has the threaded holes that the handle assembly screws screw into to hold everything in place.
