Home › Forum › Ask A Member › crankshaft seals
  • #8232
    edgartc
      What is an indicator that the crankshaft seals are bad. Abnormal carburetor settings, poor low speed, poor hi speed, will not start, all of the above?
      #64917
      RICHARD A. WHITE
        If the upper is bad, it generally will sling oil all over the points…
        classicomctools@gmail.com
        #64921
          Depends on what motor you are talking about. Some, all of the above, some you will not see any symptoms till the whole powerhead is trashed from water intrusion into the crankcase.
          #64925
          PugetSoundBoater
            Mumbles posted a You Tube video of what the bad top crankshaft seal looks like with outboard oil applied.
            Robbie Robertson
            #64929
            1957evinrude
              I was told by members here if u own a 1956 15 hp evinrude or Johnson and 1956 12 hp gale its best to replace the bottom crank seals as they are prone to failure
              #64932
                If the top seal is gone, the bottom one will probably need replacing to at the same time, especially if the motor has lip style seals instead of O rings.
                https://www.youtube.com/watch?v=cXt6fV6Z5rc
                edgartc
                  Thanks good info
                  #64963
                  1957evinrude
                    I replaced the bottom seals on my 56 15 and 12 hp engines. Its not difficult at all.
                    #65016
                    olcah
                      How did you get the old ones out without damaging the crank surface?
                      #65026
                        quote OLCAH:
                        The screw method works well but there are tools.
                        https://www.youtube.com/watch?v=l7ryeygpM2M
                        https://www.youtube.com/watch?v=tvoyD9V8_8M
                        https://www.youtube.com/watch?v=iQwulUnPxew
