Home › Forum › Ask A Member › Crankshaft Seal
  • #269222
    Dale
      Anybody know the part number for the lipped seal that comes in the evinrude/johnson 15 hp motors?   I am working on a 1956 15 hp Evinrude.  I noticed it does not have the carbon seal on the lower crank bearing.  I would like to replace it.
      dale
      #269223
        My 1956 parts list shows OMC seal #303804.
        1982 Evinrude 25hp
        #269224
        Dale
          Great!   Thanks
          dale
          #269230
          ED
            seal p/n 303804 supersedes to 321467
            #269249
            Dale
              Good to hear from you ede!   BTY is the top seal the same number?   Do you have them?   If you do let me know and I will send you an email.
              dale
              #269251
                Yes, parts list says both the upper and lower crank seals are the same number.
                1982 Evinrude 25hp
                #269268
                  I should mention that the lower seal goes in with the lip and garter spring facing out, towards the bottom. This is opposite of the top seal and is meant to keep water and exhaust out of the crankcase.
                  56-FD-Crank-Seal-2
                  63-Viking-15-Lower-Seal
                  #269272
                  ED
                    Dale, send me an email and we will conclude the sale for two 321467 seals,  Ed  eddelliott@cox.net
                    #269275
                    Dale
                      Good to know Mumbles!  Thanks everyone!
                      dale
