Home › Forum › Ask A Member › cracked throttle handle 5.5hp 1959
- This topic has 6 replies, 3 voices, and was last updated 6 years, 5 months ago by
Don.
May 16, 2020 at 1:42 pm #203233
I have a crack on one side of the two part throttle/steering handle …
motor must have been dropped and caused a slight bend which caused the crack (about 1/16 to 1/8 is offset)
are the throttle handles made of aluminum if so I will try to realign it and weld it with those rods alumiweld… or something…
thanks
This topic was modified 6 years, 5 months ago by
JACQUES.
May 16, 2020 at 2:33 pm #203235Yes they are aluminum. Also the same part was used on many millions of motors so if you can’t fix it is easy to replace.
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
May 16, 2020 at 6:09 pm #203249ok thanks… I had those welding rods for years in the cupboard in the shed and only used them last year on my “new” to me” 14 foot aluminum boat…. the 2 back corners that had splits I followed the instruction and they worked out pretty well so I give it try when I tackle it later on this year
… keeping this “gift to me” for my next winter project 🙂 If I break the other half trying to line up the crack I’ll go hunting for a new handle
June 9, 2020 at 8:17 am #205181update: tiller fixed
with the left side half, cracked in two I was going to try welding but resorted to Permatex STEEL WELD epoxy with great success !
I welded the crack with just a touch of epoxy and reassembled the tiller with screws and electrical tape to line up the parts perfectly ..like a broken leg bone
after an hour I split the tiller back in it’s two separate parts to access the inner side of the broken half. I washed out all the grease/oil , scraped the surface with my Dremel tool for a better grab.
The parts being hollow there was lots of space to coat the inner surface with epoxy over the crack and for added rigidity I just soaked in a few 2.5 inch spiral galvanized nails over the crack
Perfect fit , extremely solid and a cheap fix 🙂 Now I just need to figure those darn tiller gears…
June 9, 2020 at 2:49 pm #205218Is it an Evinrude or Johnson? I just happen to have a tiller handle from a 1959 Evinrude….
June 9, 2020 at 4:15 pm #205229Evinrude Golden Jubile 1959 Thanks for mentioning it but frankly the repairs look perfect and already coated with fresh paint 🙂 Save that tiller 🙂
June 10, 2020 at 7:45 am #205280Cool! I have been so upset lately, my work shop has been more of a dumping ground than man cave. Finally spent a couple of days going through most everything, remembering all the good stuff I have “collected”, that is when I found the Golden Jubilee tiller handle. Now, I can enjoy doing a few projects, but it won’t take long to mess the shop all up again….
