Home › Forum › Ask A Member › coupling
  • #4206
    jackmcl123
      looking for the coupling that hooks gas line from tank to carb the number i have is 3335-5206 scott atwater . it is off 5 hp scott-atwater outboard .coupling leaking can not see how to fix
      could a change this over to a johnson hook up.
      #35976
        I think I have one . got a pic.
        #35978
        jackmcl123
          looks like a mercury but it is smaller
          #35979
          lotec
            If you have a real Scott connector and want to change the o-ring, here’s what I do.
            1) Clamp the ribbed part of the connector in a vice with the ears up
            2) Soak the end well with favorite penetrating oil and give the end some gentle heat
            3) Use something like a #2 Phillips head (or any tool that fits between/under the two ears as a handle/puller) and twist & pull the retainer out.
            The retainer is only press-fit into the housing – once out you will see the check ball, spring and the o-ring. Replace the o-ring with a comparably sized new one, if you can find one that is Viton or otherwise ethanol proof, all the better! Re-heat and lubricate and reinstall the parts in the same order they came apart.
            Here is the only photo I have handy showing the Scott connectors – the top one is the original style Scott. The later style McCulloch next down is similar, but it has been a while since I worked on one of them so my memory isn’t 100%.
            #35997
            jackmcl123
              my is orig. scott connector. can i change out to say a johnson coupler
              #36000
              jackmcl123
                do you have a link for scott atwater parts.thanks.
                #36010
                  Here’s one I did a few years ago.
                  I think I pressed it apart by inserting a rod thru the fuel outlet and using a torch to heat it up and melt the Gas Ola or whatever kind of sealer they used back then.
                    I use the new and improved connector on my Scott motors. Just shove the bare hose on the male motorside connector.
                    #36025
                    jackmcl123
                      where do i get one
                      #36038
                      jackmcl123
                        man a little slow today
