Home › Forum › Ask A Member › couple gasket making installing question
- This topic has 8 replies, 6 voices, and was last updated 11 years, 6 months ago by
ddoyle.
April 14, 2015 at 7:01 am #1201
The current discussion on 2 hp OMC mysteries rekindled an interest for me in my own little duck boat motor. The project had stalled at the exhaust port inspection plate re install due to lack of gasket. I bought some felpro gasket material and hope I used the right stuff(?) took 4 fails to learn the techniques to get it close to satisfactory ( took two tries to figure out to cut the holes first and another two tries to convince myself of the need to check the holes before cutting the rest š³ LOL)
My question is: Before I install this gasket which cost me 2 hours of precious life and 8 dollars in material should I use RTV (or some other sealer) ?
It serves to seal a section of water passage and the exhaust port. It feels instinctively like I do not want the twain to meet!
Any hints would be appreciated. I have the OMC Service manual no. JM-7401 but there is no mention of it.
Here is a pic of the gasket material and plate in question. Any blue haze in the pic is the air around the evident failures.
April 14, 2015 at 11:58 am #13921I prefer to use OMC Gasket Sealer on such places. Opinions will vary.
April 14, 2015 at 12:20 pm #13925OMC gasket sealer.
April 14, 2015 at 3:09 pm #13941So it definetley needs some sealer, OMC sealer prefered. In abscence of OMC sealer what is the second best choice? Is it applied to both sides of a gasket?
Thanks alot much appreciated
April 14, 2015 at 3:47 pm #13943It ain’t rocket science. Permatex #? (the one that comes in a can with a brush in the cap) will work.
Want to know an old mechanic’s secret? I keep an old magazine on hand. When I want to apply gasket sealant, I open the magazine, lay the gasket on a page, and "paint" on the goop, thinly and evenly. Flip it over and do the other side. Peel the gasket off and install it, and close the magazine and set aside for the next job. Simply open the mag to a new page next time.
April 14, 2015 at 3:58 pm #13944quote FrankR:It ain’t rocket science. Permatex #? (the one that comes in a can with a brush in the cap) will work.Want to know an old mechanic’s secret? I keep an old magazine on hand. When I want to apply gasket sealant, I open the magazine, lay the gasket on a page, and “paint” on the goop, thinly and evenly. Flip it over and do the other side. Peel the gasket off and install it, and close the magazine and set aside for the next job. Simply open the mag to a new page next time.
Frank,
That tip alone is worth the price of admission.
Thanks, David
April 14, 2015 at 4:51 pm #13947Anonymous
I’ve used Permetex "High Tack" (brush top can) on bolts and base gaskets
April 14, 2015 at 5:18 pm #139493M847 is the usually named modern equivalent for the OMC sealer mentioned.
http://www.omc-boats.org
http://www.aerocraft-boats.orgApril 14, 2015 at 7:23 pm #13952Huge thanks guys, I managed to find a can of BRP/omc sealer. Really appreciate the application instructions. It might not be "rocket science" but I have screwed up simpler tasks thru lack of knowledge.
Looking forward to a bucket cruise in the next day or two. Again thanks for the patient answering of elementary query.
