Home › Forum › Ask A Member › Correct spark plug for 1924 Model D Elto Ruddertwin
  • #73441
      I use Champion D16 plugs in my 1924 D rudder twin with good results.
      #73451
      PM T2
        Most Champion "R" plugs I’ve seen were the side electrode type, and I wouldn’t run them in anything but a hi-performance motor.
        Antique Champion 7, or, in lieu of, the 6M or even a 5M/5MJ will give you more than enough performance and reliability to make you happy.
        I don’t run modern plugs. Period. F*** ’em. For old iron, I clean up the antique plugs I find and go with it. If your ignition and fuel settings (not mix, the carb settings) are where they’re supposed to be, you can run the antique plugs for the duration of this lifetime…. and the next….
        Best,
        PM T2
        #73577
        Monte NZ
          Thanks very much Roalco,XR55 and PM T2 for your help too.
          I have managed to get the motor out on the lake and have given it a good run.
          I checked the plugs (D 16s) and they were very sooty as I suspected.
          Interesting to note when I got back to Auckland yesterday, I managed to find the old original plugs and they are Champion 7s.!
          Thanks everyone once again.
          Monte NZ
          #73606
          jimross
            There may be a fine line between correct, original and best but those of us who have collected and run the Elto’s have always sworn by the Champion D9J for Ruddertwin, all Speedsters and ’28 Quads. The original was the Champion 7. Jim Ross
            #73628
            Monte NZ
              Thanks Jim for that info too……much appreciated!
              All very interesting and helpful.
              Thanks again for all your input and enthusiasm…….keep up the good work!
              Monte NZ
              #322195
              What do you gap the spark plug to?
              #322228
              Tom Holmes
                J48111 here
