Home › Forum › Ask A Member › Correct plug wire routing for OMC mags
- This topic has 10 replies, 7 voices, and was last updated 10 years, 8 months ago by
Don.
March 12, 2016 at 8:06 pm #3826March 12, 2016 at 9:09 pm #33311
Looks right to me…The only thing you might do is rotate the wire clamp on the head 90 degrees to port/left side of engine, you may want to route the wires below/behind the filter clamp as well. I know the wires seem like they get squished up between the vertical throttle rod and exhaust manifold, but that is the way they were routed during assembly. Adding a flexible sleeve (like that mesh stuff) covering both wires might help keep them from getting kinked/ pinched.
March 13, 2016 at 12:36 am #33332Those look too short to me. Shouldn’t they go down near the lower cowl?
March 13, 2016 at 12:52 am #33333How the heck did you get that motor so clean?
March 13, 2016 at 1:07 am #33336wannabe,
Cannot answer for Scott, but what I do to a motor that is not getting full cosmetics:
Tear off everything like mag plate, carb, etc…
Soak in WD40
Wipe off excess old grease etc…
Blow out nooks/crannies with compressed air….
Re wipe until nice and clean!Then start cleaning every parts, re greasing and re installing as you go.
March 13, 2016 at 3:32 am #33347Wish I could take credit but this is as purchased. It is in nice shape overall. I’m thinking it’s a low hour motor.
March 13, 2016 at 8:20 am #33353What’s missing is the spring which hooks onto the wires to take the slack out of them. It should be below the sediment bowl.
March 13, 2016 at 12:47 pm #33356quote Mumbles:What’s missing is the spring which hooks onto the wires to take the slack out of them. It should be below the sediment bowl.I was going to say that, but couldn’t find it in the parts book. Finally found it after considerable searching. Part #302827
March 13, 2016 at 1:29 pm #33359quote FrankR:quote Mumbles:What’s missing is the spring which hooks onto the wires to take the slack out of them. It should be below the sediment bowl.I was going to say that, but couldn’t find it in the parts book. Finally found it after considerable searching. Part #302827
Where did you find it Frank??
March 13, 2016 at 5:09 pm #33378Gale book. Item #18, attached to exhaust cover & shown way out of proportion.
free picture upload -
[/url
