Home › Forum › Ask A Member › Cork float TD-20
  • #285773
    I have. a 1948 Johnson TD-20 with a cork float, somewhere i read that the float needs to recoated so it won’t get gas logged. I used shellac to coat it. Is shellac what was used originally?
    I wonder why Johnson used a cork float and not a metal one. Seems like a weak point in an otherwise well engineered motor.
    Thanks!
    #285782
      I  believe  the mercury  round float can be  fitted  in and replace the cork float   otherwise crazy glue can seal the cork… keep fumes  away from eyes and lungs  !!
      Basic Carburetor Servicing Johnson H and T Series (pochefamily.org)
      check out the poche family site
      #285786
        Originals were coated with orange shellac. Modern gas dissolves shellac. Nuff said.  I use the Mercury Nitrophyl float. Your choice
        #285794
          In may of 2017 I drilled a hole in this cork,
          tied a weight around it and put it in this bottle.
          Over the years I’ve changed the gas a few times
          last tine being October. I just went and checked
          it and its still floating.
          #285802
          aquasonic
            The Mercury float is the best option. You just have to drill the hole slightly larger to accommodate the brass needle. It should fit snug. It’s very important whichever float you use to install the tiny clip with the screw in the top of the float, and the clip then fits into the groove in the needle. That clip controls the float and fuel level.
            Improvise-Adapt-Overcome
