Home › Forum › Ask A Member › Cork Float Clip
  • #3895
    viking66
      Hi All
      Any source for the clip on a cork float the keeps it at the correct height and is secured by the small screw?
      I need one for my PO-15. I am going through the Carb and there was not one there….Ugghhh 😄
      Any ideas on how to make one and what to use to keep the weight down?
      Thanks everyone!!!
      #33778
      david-bartlett
        I would try a small brass or stainless cotter pin or a tiny hitch pin.
        #33785
        JOSEPH BRINCAT
          that clip should be spring wire of some sort. One could be made from some small diameter music wire (hobby shop) or the wire in a ladies "bobby pin" (remember bobby pins?) would be about the correct diameter, I’m thinking
          #33788
            hardware store
            #33792
            Leon
              I might actually have one of those here. Is it the flat type, or is it the cotter pin type?
              #33798
              viking66
                It’s the flat Bobby pin style.
                #33829
                  #33833
                  JOHN D.
                    I found clips like the flat one shown in the picture at our local Ace hardware store. Look in the beaded chain and key ring section.
                    #33848
                    viking66
                      It would be the "Round with Screw". The flat would also work.
                      I plan to get to the Hardware store today and see what they have in their bins and get something that should work
                      Thanks to everyone here. I like being able to ask something and not be made to feel stupid just because I don’t know the exact name.
                      #33852
                      chinewalker
                        I’ve also made them out of paper clips. There isn’t a whole lot of tension needed on those clips and a properly bent paper clip will still have a little tension to it. Bend one up with a pair of fine nose needle nose and give it a try.
