Home › Forum › Ask A Member › cork carb floats
  • #1243
    ggoldy
      I know there’s an article somewhere about making replacement floats for an Elto Ace. I’m afraid I’ve doped mine for the last time and I can’t find the link. Would someone point me in the right direction?
      #14184
      mr-asa
        I don’t have the article, but if you’re going to the Suwanee meet and you let me know what size cork you need I’ll paw through mine and grab one that will fit.
        #14185
        ggoldy
          I won’t be at the meet and I never thought of measuring the float LOL
          Thanks anyway,
          Gary
          #14186
          mr-asa
            No problem. If you find anyone from your neck of the woods heading there I can still bring some corks
            #14209
            Goman
              Here’s some info I saved from the previous site. Don’t know if it will help you or not.
              A good grocery store usually has cork bottle stoppers. A small size is easily trimmed to fit with a 9/64" gap between it and the valve. I use a touch of 3M Scotch-Weld 847 adhesive to keep it in place. The float level should be set so the fuel is 13/16" down from the rim of the float bowl when held level. Valve spring pressure should be 3 ounces. (Carefully lowered on to a postal scale) Sierra carries a mercury float that can be trimmed to fit.
