Home › Forum › Ask A Member › control lever 1957 10 hp evinrude
  • #291638
    ALBERT MOORE
      i am in need of a control lever for a 1957 10 hp evinrude does anybody have a parts manual for the 1957 10 hp evinrude
      ? marineengine .com does not show one
      or can you tell me the part number for the control lever that controls the magneto
      al
      #291641
        clarify….control lever that controls the magneto
        vertical side post    ?
        #291642
        ALBERT MOORE
          the control lever is the vertical rod mounted on side of block the turns the magneto plate
          al
          #291643
          CHUCK
            An old post on here has the 1956 Parts Manual.  Very Similar
            https://www.aomci.org/wp-content/uploads/attachments/1956%20Evinrude%2010%20HP%20Parts%20Manual.pdf
            Interestingly the 1956 Part number is 304159  and the 1958 part number is 305517.  So perhaps the 1957 is yet another number?
            Someone will respond.
            #291645
              1956 and 57 used the 15-18 hp midsection and was charged in 1958. Might make a difference in length of the part???
              #291646
              Steve D
                These are from Johnsons but are the same for Evinrude. ’56 and ’57 are the same #304159, and as mentioned, ’58 is different, 305517.
                control-levers-1
                #291650
                ALBERT MOORE
                  thanks to everyone for your help  and thanks to Steve D,  Seakaye 12 for for the photos and the manual
                  al
