Home › Forum › Ask A Member › Connecting rev counter to 1964 3hp Johnson question
  • #270451
    Monte NZ
      I have an Airguide Rev Counter Model 65S which works well on my 1970 40hp Big Twin which
      I have made portable and I would very much appreciate help as to how to hook it up to my 3hp Johnson
      A diagram or picture would be a big help.
      Thanks in advance.
      Monte NZ
      #270459
        Assuming the tach connects to the breaker points on the 40 hp, the 3hp would be connected exactly the same way.  You will have to ren a wire to the points to do that.
        #270460
          Are you sure your tach is a model 65S and not a model 653 as I can’t find a 65S listed anywhere in the Airguide Application Guide.  They do show the 653 for two cylinder OMC/Mercs equipped with magneto ignition though, as are your Big Twin and JW motors are.
          • This reply was modified 3 years, 10 months ago by Mumbles.
          #270477
          Monte NZ
            Thanks Frank and Mumbles for your replies.
            Frank, I am wondering where I should make the connection on the magneto with the rev counter wire?……….the earth wire is ok and sorry Mumbles, you are correct, the Model No is 653, not 65S
            Thanks again
            Monte NZ
            #270480
            bob-d
              You will also have to move the transmitter box as well.
              Bob D
              0EB8013A-4ED8-4932-93A6-2CD0C59A7E77
              #270482
                You will see two black wires coming out from the under of the 40hp magneto.  They serve other purposes on the 40, among them the ignition switch.  They come from the breaker points in the magneto.  The tach transmitter connects to them, likely at the ignition switch.  Bottom line is, your 3hp does not have those wires and you will have to install one to pick up the signal.  As said, it will be connected to the points exactly like the 40 hp.
                #270638
                Monte NZ
                  Thanks bob-d and Frank for your replies.
                  I did as suggested and it works!
                  Thanks again.
                  Monte NZ by
                  #270641
                    Great.  Now tell us why you need a tach on a 3hp.  Just curious, that’s all.
                    #270696
                    Monte NZ
                      Good question Frank… . I was just curious to see what the revs were at idle and full throttle and I thought it would be fun to try it on my other motors too, that I run on my boat.  When I tried it yesterday  in the drum, the slowest idle was 900 rpm,  which I guess is about as low as it will go with compression of only  60 psi on both cylinders.
                      Thanks again.
                      Monte NZ
                      #270744
                      Monte NZ
                        In case anyone is interested, attached is a photo of my “portable ” Airguide Tachometer.
                        https://photos.app.goo.gl/C8zsNCRbxCi6zty29
