Home › Forum › Ask A Member › Condensers Testing
- This topic has 25 replies, 10 voices, and was last updated 9 years, 10 months ago by
cajuncook1.
January 9, 2017 at 5:44 pm #50737quote FrankR:I’d say that 99% of no-spark problems are due to dirty or mal-adjusted breaker points, assuming the coils and other parts are good. I’d revisit them.
I would not say I told you so, but—well never mind. Let’s both of us hope the next guy learns by reading this. And that’s why we are here.
January 9, 2017 at 6:22 pm #50740I use an old Heathkit capacitor checker that I put together back around 1960. It lets you put up to 600 volts on the capacitor and also will tell you how much capacitance it has. There are a few on E-Bay. Here’s a link to one of them:
BTW, if anyone has one of these and needs a manual, I can send a copy of mine.
Davehttp://www.ebay.com/itm/Vintage-Heathki … Sw9GhYczj9
January 9, 2017 at 6:55 pm #50741Here’s how one audio tech tests capacitors. The video is kind of long at 38 minutes but it’s thorough.
January 9, 2017 at 11:06 pm #50759quote FrankR:quote FrankR:I’d say that 99% of no-spark problems are due to dirty or mal-adjusted breaker points, assuming the coils and other parts are good. I’d revisit them.I would not say I told you so, but—well never mind. Let’s both of us hope the next guy learns by reading this. And that’s why we are here.
LOL, I deserve that. π But revisit them I did. Multiple times! As I said earlier, they looked good and I did clean them repeatedly. However, being out of ideas, and looking at the various posts (yours in particular), I figured dismantling the ignition system might be worthwhile. Then, with all the components on the bench I set about testing each one separately. That’s when I discovered the problem. I’m really surprised at how good they looked and how bad they were. π―
Lesson Learned: Test — Don’t assume because something looks good and a usually cleaning has been done that the points are good to go. Better to actually test them. π³
Without your help (and that of the other posters) I’d still be banging my head against the wall.
Thanks again!
January 10, 2017 at 3:23 am #50769quote Mumbles:Here’s how one audio tech tests capacitors. The video is kind of long at 38 minutes but it’s thorough.Really instructive video.
It explain a lot of things people without electronic knowledge ignore.One more thing, but mainly about polarized capacitors. The fabrication tolerance is usually between 10 and 20%.
So it’s not a real problem to use a "close" value π
Of course, it’s off topic for our ignitions.January 10, 2017 at 10:17 pm #50798quote stxray:quote FrankR:quote FrankR:I’d say that 99% of no-spark problems are due to dirty or mal-adjusted breaker points, assuming the coils and other parts are good. I’d revisit them.I would not say I told you so, but—well never mind. Let’s both of us hope the next guy learns by reading this. And that’s why we are here.
Thanks again!
Well now I don’t have to make the video π
When I was looking at your pictures, the points looked like they could use a good cleaning. Like Frank says, " Are they shiney clean!" You were absolutely correct in tearing the whole magneto and cleaning all the contact surfaces.
COOL! Glad you have spark.
