Home › Forum › Ask A Member › Condenser to coil matching
  • #6183
    RICHARD A. WHITE
      Here is one…
      I have a Neptune twin,
      Wico coil 3040D
      tests good both sides
      Condenser…. no numbers on this condenser
      So not able to test as I do not know what it should be.
      Mag is a Wico P2934A
      Spec. FW1102
      Serial 043825
      Any thoughts on what condenser I can use???
      classicomctools@gmail.com
      #51663
        Year? Model? I think another make used that same coil and the cap was rated around .16-.18 uF. Not sure though.
        #51669
        wagemaker
          http://www.oldengine.org/members/diesel … Parts2.htm
          Shows your magneto has an x2186 condenser.
          http://www.oldengine.org/members/diesel … agCap1.htm
          shows that X2186 condenser is .16 – .20
          That first link has other outboard models too.
          #51683
          RICHARD A. WHITE
            I can’t get those links to work here at work, but I do have a cap that fits that range…It is from a Neptune so that will be my back up..
            Thanks guys 🙂
            #51684
            RICHARD A. WHITE
              quote Mumbles:
              Not sure which model or year as it is someone else’s motor. It was at our meet last weekend and he stated he had no spark and suspected the coil.
              Offered to look it over, coil is like brand new, points were filthy, and the cap I have no clue as it had no identifiers.
              So with this new knowledge, I will test that cap at the .16-.2 ish range and see if it is ok.
              #51719
              PM T2
                Did you test the condenser to see what capacity it measures?
                #51727
                RICHARD A. WHITE
                  quote PM T2:
                  Yes, got a reading of .21 mfd, but not knowing what the actual part number of the condenser was I had no way of knowing if it was right.
                  Now I do, so time to reinstall and test for spark this weekend.
