Home › Forum › Ask A Member › Condenser repairs .22uf
- This topic has 8 replies, 5 voices, and was last updated 1 year, 8 months ago by
jeff-register.
March 3, 2025 at 1:40 pm #294436
I finally after a year or two of having purchased some ceramic condensers I tried soldering wires to these small critters and it went real well with a low power soldering iron, a touch of solder paste and 22ga wire ………. thesmall capacitor came out aliv and tested perfect at .227 nano or .22uf
should work real well and cheap to rebuild … I just need to sink them in an old condenser can with one wire soldered on the can body for grounding.
March 3, 2025 at 6:18 pm #294441Those caps should work as long as the voltage rating is high enough. I like to see at least 600 volts. You may want to pot it in the can with some silicone RTV so vibration doesn’t cause the leads to flex and break. Regular RTV outgasses acetic acid while curing, which is corrosive, but there’s an electronic grade that outgasses ethanol vapor. I used that to keep bigger capacitors from vibrating and breaking their leads when I worked for Honeywell designing temp control circuits for ThermoKing truck refrigeration units that see a lot of road vibration.
March 3, 2025 at 6:23 pm #294442I think you have a typo in your post – you wrote: .227 nano, which should be 227 nano (no decimal). The .22 uFd is correct also.
March 3, 2025 at 11:17 pm #294452yes… 227 nano ===> .227 uf 🙂
March 4, 2025 at 10:49 am #294456Those ceramic caps are rated at 1.2KV ( 1200 volts) . That’s even higher than the high quality metal foil caps which are rated at 850 volt
March 4, 2025 at 1:24 pm #294458yes some are 1.2k but mine were 630 V if I recall they are these x7R ones on amazon … price is up a bit but about $3.75 each not bad
March 5, 2025 at 8:58 am #294470Those caps should work as long as the voltage rating is high enough. I like to see at least 600 volts. You may want to pot it in the can with some silicone RTV so vibration doesn’t cause the leads to flex and break. Regular RTV outgasses acetic acid while curing, which is corrosive, but there’s an electronic grade that outgasses ethanol vapor. I used that to keep bigger capacitors from vibrating and breaking their leads when I worked for Honeywell designing temp control circuits for ThermoKing truck refrigeration units that see a lot of road vibration.
What are thoughts on using hot glue gun glue for potting in condenser cans.
March 5, 2025 at 11:21 am #294478should work .. just put some packing in an old emptied out capacitor can above the ceramic and fill with hot glue or 5 min epoxy. the ceramics are so small and delicate so I double wrapped then in shrink tubing which in itself secures, insulates and protects everything. Would not hurt to use a short length of 20 ga wire to reach the points
March 9, 2025 at 8:36 pm #294528Crosbyman,
Super job! You can get potting (hi dielectric) to insulate inside the old cap can from M.G. Chemicals on line. I have used before in a different app & works well. -
