Home › Forum › Ask A Member › Condenser for 1947 Champion 2J
  • #6813
      Anyone have information that shows what "mfd." condenser
      a single cylinder 1947 Champion 2J, 4.2 hp, with
      the Bendix Scintilla, K1-1 magneto takes?
      The old one tested at .35 mfd.
      I found a listing via "condenser number" for K series
      magnetos, and they ranged anywhere from .14 to .35,
      so it’s possible .35 is correct for mine, but then again,
      the points had a deep pit.
      My old condenser had no numbers on it.
      Thanks!
        Here’s a listing for Merc mags using the Bendix Scintilla and Phelon systems and also a photo of different automotive caps. The mounts on the Ford ones at the top might allow easier installation in a tight place.
          Mumbles, using the parts manual you sent, I found the condenser number,
          10-82104, and was able to reference to the info on
          this data, showing I need a .15 mfd condenser.
          Thanks!
