Home › Forum › Ask A Member › Condenser can stuffers
- This topic has 13 replies, 6 voices, and was last updated 4 years, 5 months ago by
JACQUES.
March 15, 2022 at 11:29 am #256271
I know Mr. Mohat’s article (condenser repairs- Outboarder series) ) recommended 850V ones but i’ll eventually try these out if they arrive.
The last strip disappeared between China and my house but I was credited by Amazon
so I re-ordered strip. about $2.50 CDN each
March 15, 2022 at 11:51 am #256274Those are surface mount caps and very small.
March 15, 2022 at 12:19 pm #256275yes but see article …
Microsoft Word – Part4_Repairing_Broken_Condensers.doc (wrcoutboards.org)
March 16, 2022 at 9:24 am #256331I have the Digikey mylar condensers and since the condensers are out of sight under the flywheel, why not just connect the bare condenser to the mag plate using the hold down screw for the original condenser and at the points connection post? No potting, no soldering. Would such a condenser fail more frequently than one potted in the old condenser can?
March 16, 2022 at 9:43 am #256332March 16, 2022 at 1:11 pm #256342Should be no problem to install a mylar cap “unprotected” under that flywheel… I have done it several times. Just be sure to secure the cap so that it doesn’t shake or vibrate and possibly fatigue the solid copper wires.
June 7, 2022 at 11:49 pm #261146So Crosbyman, how did you make out with these SMD caps? Small, aren’t they! Have you tried using them yet and if you did, how did you do it, with a breadboard or did you manage to solder them in circuit? Photos please or it never happened! ☺
June 8, 2022 at 12:34 am #261148sorry did not work on them yet ….this is summer time 🙂
I currently have all my winter projects done and a nice johnson 5.5 (white cd-11 or 12…) in the shed waiting for snow.
yes SMD’s are quite small but measure .22uf exactly and tested good on the test box I built (Mohat type 1) so if I am quick with the solder iron i’ll go with M.Mohat’s method and cover them up with epoxy to solididy them and stuff them in cans .
for some reason I feel very confident they will be fine.
June 8, 2022 at 11:49 am #261180I’ll have to go back and read the complete procedure for installing them but they could be mounted on a custom PC board which could then be stuffed in a can. There are several manufacturers in China who build custom PC boards for cheap. All you have to do is submit the dimensions and design and they will look after the rest. A fellow I know of who restores vintage audio gear does this for obsolete burned or broken PCB’s and says the return time is about one week, depending on the shipper you use.
June 8, 2022 at 12:19 pm #261185Actually just gooping them up in epoxy to soldify the welds & seems good enough and it insulates the works from the inside surface of the old condenser cans . A shot of silicone seals everything up nicely.
the round yellow ones can be simply be attached to ground and the point screws.. hidden away from critical eyes 🙂
