Home › Forum › Ask A Member › Compression required on 1940 Johnson HA, HS .to run
  • #281930
    Monte NZ
      Hi All
      Could someone please give me an idea of compression  requirements and any other suggestions to get the above motors running.
      Currently the best is  35lbs on both cylinders on both  motors.
      Thanks in advance
      Monte N Z
      #281931
      ALBERT MOORE
        you need no less than 60 psi   or greater
        al
        #281937
          As Al says, 60 minimum, but 70 to 75 to be a great idler.
