Home › Forum › Ask A Member › Compression release
  • #21166
      quote mgsolakis:
      My issue is that I can’t use the electric start without a solenoid. So there is no way to accurately test compression. Plus I was hoping that an automotive solenoid might help me get the electric start working. But that seems like a bad idea as well by the sounds of it.
      You can use jumper cables (minus to ground, plus to the starter).
      The correct solenoids aren’t that expensive (multiple sources available). Do you have the original solenoid box? If not, you don’t need to worry as much about getting one that fits! If you do, what year is your engine?
      #21174
      mgsolakis
        Won’t it spark like crazy without a solenoid?
        #21178
          quote mgsolakis:
          A little bit. Jump it at the battery to avoid a chance of fire.
          #21181
          mgsolakis
            Ok I’m confused, why jump it? Why not just hook it to the battery? And use the button start?
            #21185
              You could just hard wire the starter directly to a battery, except for the negative terminal on the battery. Tap the negative terminal to the battery post for a few seconds to crank the engine/check compression.
              #21192
                quote mgsolakis:
                You can, IF you have the proper solenoid, which you currently don’t. What the guys are recommending is for a quick compression test.
                Always hook up the positive, then tap the neg to battery as mentioned. Sparks less.
                #21200
                legendre
                  quote Mumbles:
                  quote mgsolakis:
                  Err.. the hydrogen gas produced in a lead-acid battery is definitely an explosion hazard.
                  The drill when jump-starting a vehicle goes like: Bat Red #1 -> Bat Red #2 then Bat Blk #1 -> Engine block / alternator bracket #2, in that exact order. This ensures that any arcing occurs at the block / bracket, and away from either of the batteries.
                  #21207
                    Better than a gas soaked 2 stroke outboard though! lol
                    Ill take my chances with the minute amount of hydrogen, if any. Never heard of anything happening like that.
                    I have seen outboards catch fire from sparking near them though! Ask anyone that has tested spark with the plugs out and grounded it near the head 😉
                    As stated, use the negative of the battery for the final connection when jumping the starter.
                    #21209
                      A battery only gives off hydrogen when its charging. Doing it outside in a breeze shouldn’t make it blow up like the Hindenburg.
                      #21210
                      DAN ANDERSON
                        We ain’t testing cars! Leaky smelly outboards. If you are worried about hydrogen gas, put a fan in front of the battery.
                        Dan in TN
